I had a query. We have got 2 shimadzu LC10 units and got one running fine under chromeleon. The connections this first one uses is a Com port and a GPIB interface. Is it possible to connect a second and if so how? Does it need to run via a separate GPIB or the same one as the first instrument? I am guessing it needs to run via the same board but thought I would ask.
Also if it runs via the same board, do I need to check/alter any unique address for the shimadzu interface?
Jonathan
