ChemStation Rev. B is UNBEARABLY slow
Posted: Fri Aug 28, 2015 12:25 am
I apologize for the caps in the headline, but seriously this thing is excruciatingly slow.
Computer is a Dell Optiplex GX620, Intel Core 2 Duo 3.4 GHz (yes, that old), with 4 GB RAM, running Windows 7 32-bit. The LC talks to the computer via the mfr.'s LAN card. Network settings for each LC and PC/ChemStation pair are analogous. I'm using the problem comp to post this, and it runs most programs fine.
But ChemStation is a whole other story. The software takes quite the time to load, versus the other LC next to me (similarly old motherboard, but Pentium 4 HT and half the ram running Windows XP) which is very speedy to load both online and offline modes. The fast LC computer works most functions in ChemStation almost instantly, but runs Firefox at the speed that a Pentium 4 with 2 GB (max) RAM should - just slow enough to make you hate yourself.
The slow ChemStation literally takes 3 minutes to load the sequence table. Try to change something? Insert a line in the table and you can watch it count down (about one line per 2 seconds) as it updates the line numbers below; then usually it flashes the screen white a couple times and the sequence table vanishes until you minimize and reopen the window. Insert/fill down wizard? Takes at least 2 minutes if you add more than 20 lines. Click to scroll down?... You get the picture. At the end of some long days, I have spent the wait time fantasizing about punting the tower into the street during rush hour.
I would put up with it except that today, whilst running DAD diags -- or should I say trying to run? -- the system hung (Not Responding) for 5+ minutes at a time, and couldn't communicate with the Holmium Oxide filter motor (even the simple stuff too???), causing a false negative failure for that part. A system restart fixed the diagnostics issues (time for a new D2 lamp), but it still takes more than 30 minutes to build a sequence table with 50 lines. Not kidding.
Then there was the one time, months ago, where it started working as fast as it should, equally quick as the other LC's ChemStation which works fine. Then another day, about 3 weeks later, it went back to its old antics. It does this whether or not the comp is on a network, whether or not other programs are open, though it is slightly faster after a fresh restart sometimes. I've not tried it in safe mode (w/ networking), but that's about the only thing I can think to try, and I'm about to do that now.
You guys have any ideas on why ChemStation moves like a glacier?
