HPLC 1050 autosampler problem
Posted: Thu Aug 27, 2015 8:40 pm
Hi
I have an Agilent 1050 with a 79855A autosampler (21 vials tray). The tray is not rotating correctly. Sometimes it works sporadically.
Problems:
-the unit is making weird noises when it rotates
-it stops rotating before reaching the desired sample vial and stays stuck in position
-sometimes it's unable to return to the home position and rotates slower than usual
Any help would be greatly appreciated!
Here is the run log of a failed run:
443 41e0 55df6bb2 202
Method Method started: line# 5 vial# 5 inj# 1 12:57:38 08/27/15
67 41e0 55df6bb3 0
Method Instrument running sample Vial 5 12:57:39 08/27/15
d48 41ce 55df6bd8 400
ALS 1050 1 EA 4006 12:58:16 08/27/15
0 1da8 55df6bd8 0
Instrument PMP1 did not start a run 12:58:16 08/27/15
0 1da8 55df6bd8 0
Instrument LDAD1 did not start a run 12:58:16 08/27/15
0 1da8 55df6bd8 0
Instrument LFLD1 did not start a run 12:58:16 08/27/15
67 41e0 55df6bd8 0
Method Instrument Error - Method/Sequence stopped 12:58:16 08/27/15
67 41e0 55df6bd8 0
Method Method aborted 12:58:16 08/27/15
Problems:
67 41e0 55df6bb3 0
0 1da8 55df6bd8 0
0 1da8 55df6bd8 0
0 1da8 55df6bd8 0
67 41e0 55df6bd8 0
67 41e0 55df6bd8 0
