Methods for pegylated separations
Posted: Tue Aug 11, 2015 9:48 pm
I've been working with pegylated (5 and 10kD) peptides (4-6kD) on a C18 column, and it appears that the unreacted PEG and pegylated products are eluting together late in the run.
Because typical reversed phase (C18 column, acetonitrile/water, 0.1% TFA) has worked so nicely for the peptides (eluting at 2-5 column volumes with a gradient) I was hoping to work with that method for the products as well. Are there conditions I should try with RPLC, or is there another known method for pegylated products that allows sharper resolution (I was thinking either size exclusion or hydrophobic interaction)?
Typical run:
Vydac C18 250 x 4.6 mm column
A = 0.1% TFA in water
B = 0.1% TFA in acetonitrile
10 - 50% B over 30 minutes, 1 mL/min, ambient temp.
Peptides elute at 20-25% B, product (I think) around 40%.
Any suggestions would be appreciated!
Boaz Vilozny
Typical run:
Boaz Vilozny
