Agilent 5975: how to remove the 1 piece lens insulator?
Posted: Tue Aug 04, 2015 4:07 pm
by JPoulin
EI Source Cleaning:
This is a quick question. I was surprised to see that Agilent has switched to a 1-piece lens insulator. How do I remove it safely, without breaking it! I cannot find any videos showing this. I am nervous to try without advice. All my experience is with the 2-piece insulator.
Any help is much appreciated!
Jennifer
Re: Agilent 5975: how to remove the 1 piece lens insulator?
Posted: Tue Aug 04, 2015 8:24 pm
by Erika.Miller
Hi Jennifer,
I used this style on my Agilent 5975 MS, and just gently pried it open, like with a small flat head screwdriver (not hard at all, a gentle touch will do it) and then slide apart. This always worked for me, and no damage.
Erika
Posted: Wed Aug 05, 2015 7:14 pm
by MSCHemist
I spread it apart with my fingers and slide/work/wobble the two metal parts out with my other hand (they sit in a trench in the insulator). On a side note don't over-tighten the brass set screw as I had one develop cracks in that area. Just enough so the set screw makes light contact with the insulator.
Posted: Wed Aug 05, 2015 10:13 pm
by James_Ball
As above, just spread them a little and slide the lenses out the ends. I too preferred the two piece design.
Posted: Thu Aug 06, 2015 12:11 pm
by JPoulin
Thank you for your responses!
What a nerve-wracking new addition to the ion source cleaning. :-)
Jenny
Posted: Wed Aug 19, 2015 10:31 pm
by whdees
here's a question; will the old 2-piece insulators work on the new ion source? I know some parts are interchangeable from one source to the next, others not so...
Posted: Thu Aug 20, 2015 2:15 pm
by Steve Reimer
The new one piece will prevent the accidental shorting of the lens to the body. I haven't had a problem getting the parts out of the holder.
Posted: Thu Aug 20, 2015 4:58 pm
by whdees
OK, but I'm just wondering what would happen if I fumble-fingered the one piece and broke it...
Posted: Fri Aug 21, 2015 3:01 pm
by James_Ball
The two piece should work, just be sure not to over tighten the set screw so that it makes contact with the lenses. Use an Ohm meter to make sure there is no shorting to ground before reinstalling and you should be good.
