Solvent peak shifts on GC-headspace analysis
Posted: Mon Aug 03, 2015 4:28 pm
Run into an interesting problem with headspace analysis, looking for solvents in extracts. See attached image.
The top (Data 1) is an example of our analyte, which is extracted with ethanol. The bottom (Data 2) is pure ethanol. Note the peak of interest (around 1.7 minutes) is shifted. A close-up of this shift is in the second panel.
Ethanol elutes at 1.791 minutes with great repeatability. Similarly, the peak in Data 1 (1.650 minutes) reliably elutes at that time.
Nothing tricky yet.
What's weird is that when we spike a sample of the analyte with ethanol, the peak at 1.650 minutes gets larger, and there is never a peak at 1.791 minutes. We know the peak at 1.650 is ethanol, but it should be coming off at 1.791. So what's happening?
Samples are run on a 30 m x 0.25 mm x 1.4 µm Rxi-624Sil MS column, headspace extracted after 20 minute equilibration at 140C.
Nothing tricky yet.
