How to save data results ChemStation A.10.02
Posted: Fri Jul 31, 2015 4:42 am
We have a HP 5890 II FID which is refurbished for our use. I work at a racetrack that uses alcohol racing fuel and need to test for accelerates or other additives. I am by no means well versed in the use of FID. Our previous GC was TCD and I was given full reign of use from a Chemistry teacher that used it before me. We are using ChemStation A.10.02 (1757) program to operate the GC. I was given a 'crash course' in operation since I've never used this type of GC before so everything I needed to know was fast-tracked or not given. My knowledge is limited so here is my question(s): -How do you save sample data individually inside ChemStation? After running a sample I get the data screen but I either cannot find the correct sequence of buttons or I am just overlooking them. Do I have to save each sample individually with minor variations to the name of the file or is there another way?
Our Nationals will be starting in less than 2 weeks and top brass wants this to happen yesterday.
Any help will be greatly appreciated and I thank you in advance.
WillieBill
WillieBill
