Setting up calibration on GC data analysis
Posted: Thu Jul 30, 2015 4:17 pm
Hello guys,
I am working on setting up calibration curves for fatty acids absolute quantification. One thing that I try to understand how calibration works is "response". Response in calibration is the area of the peak of interest as the manual says. However, I observed that the response of IS in the calibration (approximately 80000) is not the same number that I see in the percent report section of "correct area of IS" (approximately 10000000). Anyone can help me to understand this problem? I believe these different area of IS affects my absolute quantification since I see the different values of fatty acids in using calibration and manual calculation.
To give you more details:
1. Correct area in percent report section of IS is generated by clicking percent report under chromatogram in data analysis program.
2. To generate calibration curves, run samples (contained different concentrations of fatty acids) and use Autosetup calibration (they added automatically response in the calibration) and I manually added concentration for each response.
I really appreciate any help I can from experts!
Arum
Arum
