TargetLynx doesn't open my files
Posted: Fri Jul 17, 2015 7:49 pm
by diana23
Hi!
I just installed MassLynx 4.1 and I can't open my saved files. If I tried to open a file that i just save I can't do that from projects folder. In order to open the file I need to process data and then go to file-> open-> then look for my file.
I have same version of that software installed in other pc and over there it works pefect, I mean I can open my saved files from the projects folder.
Extension of the files is .qld
Any ideas?
Re: TargetLynx doesn't open my files
Posted: Mon Jul 20, 2015 7:35 am
by bunnahabhain
What error message do you get?
Posted: Tue Jul 21, 2015 12:50 pm
by diana23
it says "windows can“t open this file. To open this file, Windows needs to know what program you want to use to open it"
and if I want to select a program from the list, TargetLynx is not an option.
thanks
Diana
Posted: Tue Jul 21, 2015 1:56 pm
by bunnahabhain
In MassLynx, go to the TargetLynx Tab and select "View results". Then browse to the file you want to open, it should work then. Windows can't open TargetLynx for you.
