Help - SIM method set up on MassHunter
Posted: Wed Jul 01, 2015 3:40 pm
Hello fellow chromatographers,
I'll preface this by saying I'm using MassHunter GCMS Acquisition software (I think) - it's attached to a 5975T LTM GC/MSD system. I'm referring to problems I have when I try and edit the mass spec method in the Single Quad MS method parameters window. Hope that's enough info on the software (and hardware!)
I was wondering if you could give me a hand to a question I'm sure is easy enough to answer. I'm trying to set up a SIM method for an analyte, I've created the grouping of 5 ions (and am starting with a dwell time of 50 each) but the instructional guide seems to think I can set the time at which the SIM mode kicks in. Whether I have the mode as SIM only or Scan and SIM the time segment cannot be adjusted, it stays linked to the solvent delay (4 min), if I change the solvent delay to the time I actually want (around 10.50) then it alters, but I don't really want to do that. Is there any way of overriding this, as surely I should only be monitoring the ions in the window where I know my peak occurs? Last time I tried to run the SIM method given to me it looked God awful.
Any help would be appreciated,
Many Thanks,
Emily
Many Thanks,
Emily
