Split ratio
Posted: Tue Jun 30, 2015 7:31 pm
Currently working on a method that requires a split ratio of 0.1:1. That probably seems quite low (propably because it is). Somehow this got validated and up to a point it seemed to work fine but now anytime I try to run samples the inlet pressure slowly goes down until It shutdown completely.
Can anyone tell me why this is happening? Does it mean that for every one part of sample injected that 0.1 enters the column and the system cannot cope with this setting. what variables can be changed (other than the split ratio) that could stop/help this shutdown from occurring.
I know my wording probably sounds a bit novice but I would like to understand what is going on for my own piece of mind. Thanks
