problem with detector sensivity
Posted: Wed Jun 24, 2015 6:46 pm
by o.plaskon
Hello:)
I have a problem with detector sensivity. Every time when I make calibration curve, the peak area (Ai) for particular (concentration) standard increases. So e.g. for concentration 10 ug/l the peak area is e.g. 100, the next time for the same concentration 10ug/l the peak area is larger, the next time more larger and after some time the peak area is too large and I can't determine this concentration (standard) on the calibration curve. Limit of detection is better with time, but the highest concentration, which is on calibration curve decreases. I can't determine all standards, which I need to have. I can work on one calibration curve only for very short period of time. I inject the sample and standards with SPME technique. Maybe someone had a similar problem? Thank you for all answers:)
Re: problem with detector sensivity
Posted: Tue Jun 30, 2015 8:12 am
by iainconlin
Can you give more details? What type of detector, inlet settings, column etc.?
Have you tried any injections not using the SPME fibre , do you get the same effect?
Posted: Tue Jun 30, 2015 8:04 pm
by o.plaskon
Thank you very much for answer:) This SPME method doesn't influence on problem. The same situation is when I work with another method. It's the determination of THMs (sample-water)
determination of THMs:
Column-Rtx-5 (or ZB-5 - I tried also on this column) , detector ECD, direct injection
(more details I can write tomorrow)
But when I determine pesticides is the same problem:( So it isn't problem with column
Initially differences between peak areas for the same standard were lower, now peak areas vary very much e.g. by order of magnitude.
Posted: Mon Nov 16, 2015 1:52 pm
by ngocduyfc
Which types of standard curve did you use/wanted to get; might the Relationship between injection amount and the peak areas is not really linear.
