testimony on Imtakt Intrada Amino Acid column methods
Posted: Mon Jun 08, 2015 5:17 pm
Hello all,
I recently met with an Imtakt representative about using their Intrada amino acid columns for amino acid analysis. I was impressed and am considering giving their column a shot.
Information:
http://www.imtaktusa.com//wp-content/up ... o-Acid.pdf
http://www.imtakt.com/Reprint/Advion/Ad ... Note-3.pdf
I do have two questions, however:
(1) Is anyone here analyzing a lot of samples using their columns? How has that worked out for you? What kind of elution are you using? What problems have you encountered? What is the column durability like (how many injections)?
(2) What is your sample prep to quantify free amino acids from biological fluids or fermentation broths?
Thank you so much for answering any of the above questions!
Arne
Information:
Arne
