Sodium Dodecyl Sulfate interaction with PFP column
Posted: Fri Jun 05, 2015 2:16 pm
I am running a method using a polyfluorophenyl LC Column. I am analyzing Taxol samples prepared in Sodium Dodecyl Sulfate in pH 4.0 buffer solution. I am having continuous issues with inconsistent retention time and peak response reproducibility for the taxol peak using multiple columns of the same type and 57:43 Water:ACN as mobile phase. I've tried washing the column with a 50:50 Methanol Water mix but the issues keep returning. Has anyone experience using SDS on a Phenyl column, and knows of any issues there may be when using this combination?
Thanks for any advice.
