Lower total GC column pressure than the set value
Posted: Mon Jun 01, 2015 1:20 pm
Hi Dear.
Firstly I would like to thank you for acceptance to join your forum which will be very helpful for me .
Secondly Ihave a problem with the total pressure of GC column than the set value although all fittings are tight and the carrier gas cylinder is nearly full and my setup is :
GC-17A
Carrier gas...nitrogen
Flow rate ....3ml/min
Splite ratio....50
Inj. temp....150 C
Det. temp....250 C
Column...DA-Carbowax 20M
Thanks.
GC-17A
Splite ratio....50
Inj. temp....150 C
Det. temp....250 C
Thanks.
