Two L-menthol peaks with RP C8 150 mm x 4,6 mm
Posted: Tue May 26, 2015 8:38 am
by Nahru
Greetings,
First time posting here, though I've been browsing the forum from time to time.
I may have a problem. I'm trying to assay L-menthol, using an RP C8 column. The problem is that I have been consistently obtaining 2 peaks. I've ran blanks (both just mobile phase and placebo sample), and they never show those 2 peaks, only the standards and samples which contain L-menthol.
Using UV detection at 197 nm and isocratic elution with a mixture of acetonitrile:water. The peaks are well separated, one at ~ 9,1 min and the other at ~ 12,5 min. The baseline is consistently relatively flat. Both peaks are linear (from 30 - 150 ug/mL), as well as their sum. Recovery tests, using the sum of areas for those 2 peaks, show R% to be around 100 %, when adding known volumes of standard solution to blank samples, and then assaying them (R% is from 97,5 % to 102,5 %).
I've been using the sum of areas of those 2 peaks to assess the content of L-menthol in a sample, and what I get is consistently correct content of L-menthol (with regards to theoretical content).
Could it be that L-menthol changes its configuration during preparation? The solvent for standard and sample is the mobile phase. Perhaps one of the peaks is an impurity (standard is of 99,56 % purity, determined via GC)? Perhaps one of the peaks is a degradation product of L-menthol?
Thanks for all the input in advance.
Re: Two L-menthol peaks with RP C8 150 mm x 4,6 mm
Posted: Tue May 26, 2015 10:59 am
by mattmullaney
Hi Nahru,
I don't know whether or not there is a degradation product in the standard you're using, my thought is that it may be another enantiomer of (-)-menthol [maybe (+)-menthol?] that is present in the standard material you're using...or possibly as the standard is separated within the column multiple conformers of (-)-menthol are formed, as you suggest. This kind of thing often happens with Schiff bases--which are not anything like menthol--but maybe the chair form one would expect (-)-menthol to adopt has a companion?
My vote is for the presence of (+)-menthol in the standard and sample...however unlikely that may be.
Please, see what others have to say as well and thank you!
Posted: Tue May 26, 2015 12:08 pm
by Nahru
Hi Nahru,
No, thank you for the effort.
The issue may be that I've been using a working standard, which normally is used by my Company's manufacturing sector. I have ordered a true analytical standard, only L-menthol, after which I should know more. To my knowledge, it *should* only be (1R,2S,5R)-5-methyl-2-propan-2-ylcyclohexan-1-ol [or (-)-menthol], as that is what the certificate from the supplier states, but I shall double check again.
I am also considering the presence of (-)-menthol and (+)-menthol in the standard ("standard"), that is - basically a racemate. The peaks really are well separated, (almost) no interference, both are linear, and recovery tests show what they should (on average +/- 1 % of variation)...
Will check more later, when I get the standard (-)-menthol in a few days time.
Posted: Tue May 26, 2015 12:44 pm
by mattmullaney
Hi Again, Nahru,
Understood, and Best Wishes! It'll be interesting to see how things turn out.
Posted: Wed Jun 03, 2015 7:54 am
by Nahru
Just wanted to finish this. Obviously, only one peak can really be menthol (D and/or L), because I'm using non-chiral column, and I haven't used derivatization to make them diastereomers. I don't know how this didn't occur earlier to me... Anyway, it turns out it's most likely some sort of impurity, my guess being related substances formed during the production of L-menthol.
Posted: Wed Jun 03, 2015 9:12 am
by mattmullaney
Hi Nahru,
Understood, and thank you. As you said, the first standard material you used (if the analytical standard containing 100% (-)-menthol hasn't arrived) was a working standard typically used by the manufacturers...makes some sense that if that source is man-made there could be process impurities within it.
Menthol is interesting...the naturally-occurring stuff is 100% (-) if I believe the Internet. Weird that the man-made stuff isn't necessarily enantiomerically-pure unless a lot of work is done upon the prepared menthol!
My thanks for the discussion, sir, and again, Best Wishes.
