Controlling UltiMate3000 with Xcalibur Roadmap
Hello all,
It was a battle but I finally got the Roadmap to recognize the Chromeleon server. The documentation out there is horrible. I'm having some last problems which I'm hoping someone can solve.
When i try to set up a sequence it won't let me put in values for autosampler position or injection volume. I can't figure out for the life of me if there's someone to configure them. I can't activate panels from within roadmap and just have to start chromeleon xpress but starting the program manually. So if I try to put in the auto sampler position of "RA1" it tells me it's invalid and I should put something like "1", which if I input is refused anyway and I have to close the program!
The key thing is our MS is on a computer with Windows Vista which is not officially supported. I don't know if this is going to be an issue that can't be solved or I'm just missing something. Thermo's tech support was not very helpful.
What versions of Xcal and dcms link do you have? I have previously fought ( and won) strange issues between the two softwares!
It sounds like you don't have proper connection between xcal and the server..
If it is possible i don't mind trying a remote session via team viewer to see if I can crack it.
Let me know and i can provide my e mail for you to send the log in info.
Kind regards
Leadazide
I know this post is old, and this is a long shot, but would either of you be able to provide the DCMS Link software?
In total there are 37 users online :: 0 registered, 0 hidden and 37 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 37 guests
