Extraction efficiency phytohormones
Posted: Tue May 19, 2015 4:08 pm
Could anybody tell me what the accepted extraction efficiency for plant hormones is generally accepted for publishing in journals? I have over 80% for one of my hormones but the other is being problematic. I have repeated the extraction efficiency five times (I've also changed the protocol a number of times to optimise) and each time I get somewhere between 60-65%. Is this acceptable?
Thanking you in advance
