Shimadzu HPLC
Posted: Thu May 14, 2015 4:49 pm
I am using a Shimadzu LC with a SIL-10AF auto sampler, for ethanol. I am currently experience an injection problem that I cannot figure out. The areas on my peaks are all very high, which is causing, obviously my concentrations to be too high. I have changed out the rotor, stator, needle and clipped tubing going into the needle. I also injected with my column disconnected 200ul of 70% methanol, to see if I had a plug that I just didn't find, I did this 12 times, then ran my mobile phase at the same volume, reconnected everything ran an injection of mobile phase and then my standard, that should be 12% ethanol, and it came up to 21%, does anyone have any suggestions what could be going on here?
