Would like to change the -70eV setting on and Agilent 5972
Posted: Wed May 13, 2015 5:46 pm
by Davidcmh
I am running an Agilent 5972 MSD with Chemstation version B.01 and would like to change EI energy from the default of -70eV. I have found where these setting are in Chemstation version E.02 when using a 5973 MSD, but that doesn't help me with the 5972. I suspect that these settings are not readily available in the older software and are buried in a config or .ini file that I will need to manually edit. Any help is appreciated.
-David
Re: Would like to change the -70eV setting on and Agilent 59
Posted: Thu Jun 04, 2015 9:39 pm
by mckrause
David -
To the best of my knowledge the -70eV is hardwired on the '72s; it was on the '70s and the boards are essentially the same.
Mark Krause
