Problems with Column sizes
Posted: Thu May 07, 2015 3:04 pm
Hi everyone,
I work with an Agilent 7890B GC system. I have a estándar method to cuantify 8 analites, The method specifies to use a cyanopropylphenyl 14% - dimethylpolisiloxan 86% 60m, i.d.0.25 mm, 0,25 um film column but i have another column, same movile fase but with this dimentions 60 m, i.d. 0.32 mm, 1 um film, When i inject a sample i can see al the analites but when i inyect the std no analites are visible. I preparate several times the std. My question is this, if the dimentions of the column change, i have to change another parameter to?, Vol injection, temperaturr of the oven, temperature of injector?, temperature of detector?, any flows?,
any help will be accepted, thanks
