ChemStation signal graph offset
Posted: Fri May 01, 2015 5:43 pm
We have noticed an issue the signal graph generated by ChemStation. The GC it is connected to is generating a positive signal off of its FID in the range of tens of pA. We can bring up the relivant signal-in infromation in ChemStation that is likewise reporting values of tens of pAs. The graph is being drawn with a lower bound of -100 pA and the line representing the signal response stays below 0 pA, as though somehow 100 pA is being subtracted from our signal.
We have gone through the method and can see no evidence of any subtractions being done.
How to I restore the chart to reflect the actual signal values?
