ChemStation Sequence Table window too large
Posted: Wed Apr 29, 2015 12:18 pm
by BrianDozd
Is there anyway to resize the Sequence Table window on ChemStation? I have one system where the default screen resolution causes the Sequence Table to open up absolutely huge, and taller than the screen. First and formost among the problems with that is that the lower parts of the Sequence Table screen are cut off beind the taskbar. Secondly, there's just so much absolutely wasted space; we'd be happy with just enough room for ten lines of the table or so and the rest of the window as small as possible.
Changing the screen resolution does shrink the Sequence Table window to a more appropriate size, but the rest of ChemStation is practically useless that way with everything we need to see and the stuff ChemStation won't let us remove.
So I just need to reduce the default size of the Sequence Table window. Can anyone point me in the right direction?
