Coulmn Backpressure problem
Posted: Sun Apr 26, 2015 2:51 pm
Dear All,
I am working with production scale DEAE ion exchange chromatography. The problem we are facing is that, when the column is packed, we are not able to get the optimal operating flow rate. We have check for any problem with pump and skid but they are operating at their design specification. However when fluid is pass through the column either in upflow or downflow we are not getting the flowrate. We pack this column at 3 bar.
My question is, in what way resin might be contibuting to backpressure? is reducing packing pressure will help? If piston is withdrwan to what extent it will effect the column efficiency?
Will really appreaciate some guidance on it.
