HPLC Performance Qualification (PQ)
Posted: Fri Apr 24, 2015 5:55 pm
In an attempt to bring our lab more in line with industry standard and cGLP requirements, we are implementing PQ testing on our new LCs. In the past, we've considered our monthly verification (flow rate check, column compartment temperature check, and injection linearity) along with our daily system suitability requirements as our PQ. We do have the manufacturer (Agilent, in our case) perform their IQ and OQ, then we supplement that with our internal IQ/OQ procedure (which, basically, ensures the proper documents are in place, but doesn't perform additional physical testing of the system).
My question is: what is the industry standard for PQ? From what I can tell, most companies perform a PQ after annual PM as well as after any unscheduled maintenance. I can't seem to find any specifics on what that PQ testing entails.
We are thinking about using 2-3 validated methods to determine assay results on our "unqualified" system and comparing those results to those obtained on a "qualified" system. This approach seems to make sense to me, as obtaining an assay result will require system suitability to be performed and will challenge the new system to perform as expected. But is this approach the "industry standard"?
Also, I realize that we are held accountable to our internal SOP and that document defines PQ for our company. I want to make sure we set up that SOP to "industry standard". Currently, it states that assay results will be obtained and compared to those obtained from a qualified system, but gives no specifics (what methods, how many methods, how many sample replicates, etc.).
Any advice/guidance is appreciated.
