Simulated Distillation Software
Posted: Tue Apr 21, 2015 5:04 pm
by ochemwiz
Hello people,
This is my first post! I'm currently using Dragon SimDis by Envantage for high-temp simulated distillation analyses, and its been causing a lot of problems with its glitches and errors. It has resulted in down-time and errors in reported information to clients. I would like to know if there's anyone out there who uses a different software successfully, with no issues.
Thank you in advance :bom:
Re: Simulated Distillation Software
Posted: Tue Apr 21, 2015 9:01 pm
by TomGrills
Hi ochemwiz -
I'm sorry that you are experiencing these issues.
Please contact me directly and I'm sure we can work through whatever issues you are currently experiencing. Either contact me through our website at www.envantage.com or via email (TGrills@envantage.com)
Tom Grills
Information Services
Envantage, Inc.
Posted: Wed Apr 22, 2015 12:41 pm
by AICMM
ochemwiz,
Agilent has SimDis software which I have not tried but might work for you. I suspect it may be re-branded Envantage but I am not sure. Last I chatted, there was a demo CD available.
Separation Systems out of Florida has a SimDis software package that I have used which is very solid. Occasionally the software will shut down but a re-start and re-process usually works right away. The system I have experience with runs on a Chemstation based data system but I believe they support other formats. For routine data crunching it works quite well.
Best regards,
AICMM
