I have problems with parts Auto tune in ion trap 240 GC / MS. Look forward to the suggestions from everyone.
Here is the error when performing Auto tune.
May 22 08:34:56: QuickVerify Started.
May 22 08:34:56: QuickVerify Completed.
May 22 08:34:57:
May 22 08:34:57: ******************************************
May 22 08:34:57: Integrator Zero Adjustment Started
May 22 08:34:59: Integrator Zero Adjustment Set: 256
May 22 08:35:00: Integrator Zero Adjustment Set: 512
May 22 08:35:00: Integrator Zero Adjustment Set: 384
May 22 08:35:00: Integrator Zero Adjustment Set: 320
May 22 08:35:01: Integrator Zero Adjustment Set: 352
May 22 08:35:01: Integrator Zero Adjustment Set: 368
May 22 08:35:01: Integrator Zero Adjustment Set: 376
May 22 08:35:01: Av. intensity: 0.474
May 22 08:35:02: Integrator Zero Adjustment Completed
May 22 08:35:02:
May 22 08:35:02: ******************************************
May 22 08:35:02: Electron Multiplier Gain Adj started
May 22 08:35:05: Integrator Zero Adjustment Set: 376
May 22 08:35:05: Integrator Zero Adjustment Set: 276
May 22 08:35:05: Integrator Zero Adjustment Set: 326
May 22 08:35:05: Integrator Zero Adjustment Set: 351
May 22 08:35:05: Integrator Zero Adjustment Set: 363
May 22 08:35:06: Integrator Zero Adjustment Set: 369
May 22 08:35:06: Integrator Zero Adjustment Set: 366
May 22 08:35:10: Electron Multiplier voltage setting is 1800
May 22 08:35:11: Settling -- Fil bias: -25000 gain events: 1242 (samples: 20140) mean: 175.2
May 22 08:35:12: Settling -- Fil bias: -25000 gain events: 1193 (samples: 20140) mean: 150.6
May 22 08:35:12: Settling -- Fil bias: -25000 gain events: 1201 (samples: 20140) mean: 180.2
May 22 08:35:13: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:14: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:14: Electron Multiplier voltage setting is 1900
May 22 08:35:14: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:15: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:16: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:17: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:18: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:18: Electron Multiplier voltage setting is 2000
May 22 08:35:18: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:19: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:20: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:21: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:21: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:21: Electron Multiplier voltage setting is 2100
May 22 08:35:22: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:23: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:24: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:25: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:25: Electron Multiplier voltage setting is 2200
May 22 08:35:26: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:27: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:28: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:29: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:29: Electron Multiplier voltage setting is 2300
May 22 08:35:30: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:31: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:32: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:33: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:33: Electron Multiplier voltage setting is 2400
May 22 08:35:34: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:35: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:36: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:37: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:37: Electron Multiplier voltage setting is 2500
May 22 08:35:37: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:38: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:39: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:40: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:40: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:40: Electron Multiplier voltage setting is 2600
May 22 08:35:41: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:42: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:43: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:44: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:44: Electron Multiplier voltage setting is 2700
May 22 08:35:45: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:46: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:47: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:48: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:48: Electron Multiplier voltage setting is 2800
May 22 08:35:49: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:50: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:51: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:52: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:52: Electron Multiplier voltage setting is 2900
May 22 08:35:52: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:53: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:54: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:55: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:55: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:55: Electron Multiplier voltage setting is 3000
May 22 08:35:56: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:57: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:58: Settling -- Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:59: Fil bias: -25000 gain events: 0 (samples: 20140) mean: 0.0
May 22 08:35:59: Electron Multiplier Gain Adj failed
May 22 08:36:00: Electron Multiplier Gain Adj completed
May 22 08:36:00:
May 22 08:36:00: ******************************************
May 22 08:36:00: Auto Tune Validate started
May 22 08:36:00: Validating mass 69.0
May 22 08:36:08: Validating mass 131.0
May 22 08:36:14: Validating mass 264.0
May 22 08:36:20: Validating mass 414.0
May 22 08:36:26: Validating mass 464.0
May 22 08:36:32: Validating mass 614.0
May 22 08:36:38: Auto Tune Validate completed
May 22 08:36:38: ----------------------------------------------------------------------
May 22 08:36:38: Auto Tune Failed(Electron Multiplier)
May 22 08:36:38: Integrator Zero Dac: 376 PASS
May 22 08:36:38: Electron Multiplier Voltage:1300 FAIL
