Best column for long chain FAME analysis?
Posted: Fri Sep 30, 2005 12:58 pm
by kletterflo
Hi, I have to establish GC-MS-analytics of FAMEs, especially from skin in our lab.
The problem is that skin samples contain long chain fatty acids (up to C26-C27) among the shorter ones.
Does anybody has a hint for me which column's best for this task (excellent resolution of short FAMEs AND very long FAMEs in the same run)?
At the moment I'm using a 35%-phenyl-65%-dimethylpolysiloxane-column (Supelco MDN-35, 30 m, ID 0.25 mm, df 0.25 um), but I have bad resolution of the longer chain FAMEs.
And which manufacturer produces the best columns?
Thanks a lot!
Flo
Re: Best column for long chain FAME analysis?
Posted: Fri Sep 30, 2005 1:31 pm
by famahyari
Hi
I think that a polar column such as omegawax or PEG is useful.
for more iformation u can see also www.sigmaaldrich.com .
u can search the internet for bulletins of supelco.
I can send u bulletins of supelco.
my email:famahyari876@yahoo.com
best regards
Posted: Fri Sep 30, 2005 4:10 pm
by Consumer Products Guy
We use cyanopropylsilicone phases for FAMEs. I think the PEG phases may not be able to go to high-enough temperatures for the long chains required here.
FAME
Posted: Fri Sep 30, 2005 4:41 pm
by chromatographer1
SP-2380 or a bonded cyanosilicone column would be a good idea for the higher carbon number FAMEs. A shorter than usual column 10-15 meters might be an excellent choice.
If a saturated and unsaturated C24-C28 FAMEs separation is not to be maximized, perhaps a Equity-1701 or a Equity 5 might be a solution.
What I use for Policosanols
Posted: Mon Oct 03, 2005 2:04 pm
by Tony_Montanari
I am analyzing Policosanols which are C20-C30 alcohols. I am using a Supelco SAC-5 30m column. I start out at 100C and ramp up to 300C in 10 minutes and maintain 300 for 15 minutes. Even the C30 alcohol elutes fine.
Best Wishes,
