Empower Field Export - missing Peak Results
Posted: Wed Apr 08, 2015 2:09 pm
by djthomaskatana
I have created an export Template that includes Fields export (.txt file) that includes the Peak Results fields. The Peak Result fields appear in the txt file export, but the peak values are missing (instead, there is a ****). However, if I include the Peak Results table in the file export, the appropriate values are included in this table (i.e. there is no ****, but rather the actual values expected. Does anyone know why this has occurred?
Thank you.
