Agilent 7890A
Posted: Fri Apr 03, 2015 2:21 pm
Hello:
I was analyzing our daily standard in a splitless mode on a 7890A GC and sometime during the run time we got a message of "Insufficient power, system halted"! I turned off the system a few times but he message does not go away. I was told by Agilent to check the voltage at the wall and it reads fine. Then I was told it could be a board issue, but you have to try different boards to figure out if this solves the problem. Any suggestions is greatly appreciated.
Thank you very much for your time.
