reducing ammonia on a Waters UPLC
Posted: Mon Mar 30, 2015 11:42 am
Hi everyone,
I am using a Waters UPLC with the AccQ-Tag ultra method for amino acids. I have large NH3 peaks (that is not caused by contamination) that are masking the CYA (cysteic acid) peaks. I just put a brand new column on and the separation between these peaks is 0.1 mins so I can not see the small CYA peaks anymore because of the NH3 tails. I am able to see the CYA peak when that peak is larger or if I have a sample with a low NH3. With my older column the separation between these peaks was 0.15 mins and I could see all the smaller peaks. But that column is now unable to be used anymore.
When i did a CYA MDL i was able to see these smaller amounts, but then again it was when the separation was at 0.15min
Does anyone have any method modifications to help? Wavelength, buffer changes, temperatures, etc? I am willing to run each sample with 2 methods (standard to get the AAs and modified to get CYA and NVAL if needed)
OR know anyway to reduce/remove NH3 before derivation?
Or know if I concentrate my sample more than recommended if CYA and NVAL if develop fully? Then i can run again with more diluted sample to get the other AAs?
thanks for any advice.
