precision problem
Posted: Wed Mar 18, 2015 4:31 pm
hi sir,
iam facing problem with GC calibration.
The details are
Gas chromatograph; Make : Shimadzu; Model GC-2010
Standard ; 1250ppm of biphenyl in n-heptane, 5 injections in single vial
Capillary column; BP-1 30m,0.53mmID,1µm
Injection Volume;2µl
Column oven Temp; 130°C
Injector Temp; 250°C
Detector Temp;250°C
Split Ratio;1:1
Viscosity delay time ;0.2sec
Column flow;10 ml/min
total flow; 23 ml/min
And finally we get the %RSD is 3.9 against 2.0%.
please find What problem going with these parameters.
Thanking you sir
Sreenivas.B
Divi's laboratories ltd
Vizag
Mail;bobburi496@gmail.com
The details are
Detector Temp;250°C
Split Ratio;1:1
Thanking you sir
Sreenivas.B
Vizag
