I recently acquired a turbo pump version of the Saturn 2000 to replace a diff pump version that had stopped working. In setting it up, I noticed connector J3 on the back of the MS labeled "Turbo status." I cannot find this connector mentioned in the documentation anywhere. Should there be a cord connected here to the computer (or other)? If so, where does it go?
Mark
