Manual Integration Error Message on Masshunter
Posted: Mon Mar 16, 2015 6:18 pm
I've been running into the below error message on the Masshunter Quantitative Analysis software. Have any of you seen this and know how to correct it? I've tried everything I can think of, and can't find any help on it in the manuals. Thanks in advance if someone has a solution for me.
"Manual integration failed...........Method of this batch is invalid: Calibration STD path mismatch between target and ISTD. Please edit the method to fix this problem."
