LC-MS, help with chromatograms
Posted: Fri Mar 13, 2015 5:43 pm
Hello guys, I am new here and I need help with my chromatograms. I am rookie at this and did it for the first time. For the introduction, we had few samples and we wanted to determine the amount of compound in a sample. I have selected one mass (775 m/z) from TIC chromatogram in different samples. I was told to integrate the peaks in chromatograms (I don't know if it is integrated correct, I did for an ilustration|. Only I see there the numbers are decreasing from the top to bottom. I would like to know few facts. Please help me.
a) Did i get the amount of the area under cover like in chromatography with for example UV detector ? Or is intensity of this ion (775m/z) or what does that number above a peak mean?
b) Is it possible to determine somehow the quantity of the product if i know the concentration of solution used for analysis?
c) If I can't use it to determine accurate concentration. Is it possible at least to compare the samples in which is more or less of that compound (775m/z) from these numbers ?
I really appreciate all the help from anybody.
Thank you.
Here is the image with chromatograms
http://postimg.org/image/c1avety2d/
Thank you.
