Baseline noise
Posted: Sun Mar 08, 2015 1:37 pm
Hi everyone,
I have recently encountered some real issues with the baseline noise increasing on hplc system. We have had some issues with our suppliers for mobile phase and and after doing tests with the dtetector this confirms that its the mobile phase which is causing these poor baselines. Currently using Dionex ultimate 3000 Uhplc systems with the detector set at 214nm wavelength.
Does anyone have any suggestion for how the mobile phase could be prepared? We use acetonitrile buffered 4.3 pH for the method set up. It is currently prepared using the following: Dissolve 2.72 grams of sodium acetate trihydrate (NaC2H3O2.3H2O) in 500 ml of distilled water. Dilute to one litre.
Use 6.5% v/v Sulphuric Acid (H2SO4) or 1m sodium hydroxide to adjust the pH to 4.3.
Add 72 ml of Acetonitrile (CH3CN) and mix well.
What would be causing the noise and also the peaks are not the best. Any help would be appreciated and advice of better preparation of mobile phase.
