Column Unions
Posted: Wed Mar 04, 2015 3:37 pm
I have 2 GC/MS methods that I need to run. The first is a full scan over 50-350 amu. The second is a SIM (161, 177, 198 amu). Both methods use a 1 m x 0.53 mm ID guard column connected to a 30 m x 0.25 mm ID x 0.25 um column. My question is what is the best way to connect the columns? I have the press fit type connectors or should I use something like the Agilent Ultimate union that uses the flexible metal ferrules and the deactivated union?
Thank you for your help.
Dave
Dave
