Agilent 1100 MSD (1946B) baseline noise
Posted: Wed Feb 04, 2015 3:28 pm
Help please, I am quite new to MS and have a problem that is way beyond me.
We have an agilent 1100 LC system with a single quad MSD detector - model number 1946B. We are using the system to analyse the tannins in plant extracts, so the MS is used in TIC mode to give us the mass of the eluting uv peaks.
The system was shut down over the xmas break and after restarting we have a very noisy MS baseline.
This is a typical result before xmas, uv at 280nm (above) and TIC negative below.
And here is a similar sample run (using the same LC/MS method) after xmas.
Does this look like contamination or an electronic problem or something else. I can provide details of LC and MS parameters but dont really know which of these will help.
Note, the problem is the same in positive mode.
Chris
Chris
