Compatibility Macro Agilent Visual Basic 6/ Win7.... HELP!
Posted: Wed Feb 04, 2015 10:35 am
by lalope
Hi everyone,
I was using a custom macro called Man_FC.mac on my Agilent 1100 LC Prep/Chemstation A 10.02, which is very usefull to perform manual fraction collect during LC Prep method developpment... It add a button on the system diagram (a tubing with drops...) wich can activate/stop collect by clicking.
Recently I decided to change the PC running Win XP to a new PC runing Win7 and to upgrade the chemstation software A 10.02 to B 04.03. I planned to continue using the macr Man_FC but, if this installation is ok, the button has no effect on the fraction collector and an error message appears in the command line...
Does anyone know how to modifiy this macro in order to use it with B 04.03/win7 ?
Thank you !
Re: Compatibility Macro Agilent A 10.02 to B 04.03 .... HELP
Posted: Wed Feb 04, 2015 1:32 pm
by GasMan
Generally the macros themselves will work in XP and Win 7. The problem can be if the macro calls a procedure written in Visual Basic 6 or lower. These procedures will not run in Windows 7.
Gasman
Posted: Wed Feb 04, 2015 1:45 pm
by lalope
Gasman
So the solution is to rewrite the procedure in the later Visual Basic version ? do you know anyone who can do this ?
Posted: Wed Feb 04, 2015 6:38 pm
by GasMan
I would contact the person or company that supplied you with the macro. I have looked at the macros supplied by Agilent with the ChemStation software and do not see the macro that you mention. You say that this is a custom macro, so who supplied it to you?
Gasman
Posted: Thu Feb 05, 2015 8:13 am
by lalope
The macro was given to me by an Agilent technician long time ago (2004 maybe....) I you want I can send it to you to take a look...
I think it was a custom macro from Agilent but I'm not sure...
Regards.
Posted: Thu Feb 05, 2015 9:44 am
by dblux_
The macro was given to me by an Agilent technician long time ago (2004 maybe....)....
Maybe he is still alive :) and in the business. Find him and place an order to correct that macro.
Posted: Thu Feb 05, 2015 12:00 pm
by lalope
I was told that Agilent doesn't develops this macro anymore because they have integrated the function ton their new software Open Lab which runs under Win7.
Posted: Thu Feb 05, 2015 3:05 pm
by dblux_
A kind of planned obsolescence of the software.
Seems that you will get new skill of debugging ChemStation macros :)
Or a generous person helps you with neccessary modifications.
Posted: Fri Feb 06, 2015 7:52 am
by lalope
I think it will be the second one... :)
