cleaning validation
Posted: Thu Jan 15, 2015 1:50 pm
by ydna6969
Hi ,
I need some stainless steel plates for a cleaning method I am going to validate.
Anybody know where I can source these from ?
Usual searches not up to much
dimensions 10x10 cm (2-3 mm thick) up to 25 x 25cm (2-3mm thick)
Re: cleaning validation
Posted: Thu Jan 15, 2015 3:19 pm
by algae man
I would try a local welding shop or metal fab. If they can't get it for you direct, they can probably send you in the right direction. Probably even help if you need a certain grade.
Posted: Thu Jan 15, 2015 3:38 pm
by KM-USA
See McMaster-Carr
http://www.mcmaster.com/#standard-stain ... es/=vh7n4q
Possibly Grainger.
Many different types of stainless steel too.
Posted: Fri Jan 16, 2015 8:02 am
by mattmullaney
Hi ydna6969,
If you're in the US, I'd try GlobePharma, in New Brunswick, NJ. That's where a company I worked for purchased theirs:
http://globepharma.com/cleaning.html
Their website is, well, challenging, but their products (at least in terms of their coupons) are rather good.
Best Wishes!
Posted: Wed Jan 21, 2015 5:00 pm
by Klaus I.
Hi ,
Sorry, but I have to disagree with the answers of my colleagues above.
For cleaning validation you have to get the correct material e.g. steel plates from the manufacturer of the respective reactor vessel.
