Ammonium acetate pH drift
Posted: Thu Dec 04, 2014 10:37 pm
Hey All,
I am running HILIC mode LCMS (metabolomics) using 20mM ammonium acetate pH 9.6 and ACN gradient. The problem I am running into is that the pH of ammonium acetate buffer decreases by about 0.1 units per day and quite a few metabolites shift greatly in both intensity and retention time. Labs running similar methods say they prep the buffer fresh daily, but I would like to find a longer term solution. I initially tried using a gas tight bottle cap with a one-way air valve, which helped a little, but pH still drops fairly rapidly and so I had a few questions:
1) Would chilling the buffer in a fridge help while it was connected to the LC? I have in-line heaters I can add to the LC system to bring the temp back up before it hits the column.
2) I have a N2 generator in lab and so would it be helpful to add a stream of N2 into the bottle (to help with CO2 absorbtion)? If so is there a general how-to on how to set this up (i.e. what pressures to use)?
Thanks for any help in advance!
