Cold Trap O-ring Change Markes Thermal Desorber TD-100
Posted: Wed Dec 03, 2014 10:20 pm
Hey,
I am planning on changing the cold trap oring for the first time on my markes TD-100. Wondering if you of you might have done this before. For those who are familiar, this is not the oring connected the removable solenoid assembly. This is on the opposing side. i would says it seals the top of the trap, its closest to the weak sorbent bed. It appears the entire peltier must be removed or at least pulled back to access the oring. Just wondering if anyone can confirm this is true or any pointers to successful completion. This procedure seems to not be mentioned in the user manual.
thanks all!
thanks all!
