Negative peak in gradient HPLC
Posted: Mon Dec 01, 2014 5:59 pm
Hi everyone,
I have run the gradient HPLC on my samples which were dissolved in the solution (Acetonitrile: Water: Acetic acid) (3:6:1). I have got the desirable peaks from this type of samples. I have to say that my mobile phases are 20% and 55% acetonitrile.
I have collected the fractions during the specific time range and freeze dried them to reduce the volume. As it gets over-dried, I have dissolved it in 60% acetonitrile. After running this new sample with gradient HPLC, I have got negative peaks. I am not sure what is the reason of getting this negative results. Is it related to the high percentage of acetonitrile presented in the sample solution?
If you have any experience regarding to solve the negative peak problem, please give me your advice.
Thanks a lot,
Elham
Thanks a lot,
Elham
