Ion chromatography for metal ions
Posted: Sat Nov 15, 2014 3:03 pm
Hi everybody in this forum,
I need to remove Fe3+ from a solution and I was given the following resin http://www.bio-rad.com/en-us/product/ma ... ange-resin
I guess that according to resin properties (sulfonic acid group, 25 um particle size) it should be a good choice for binding Fe in the solution. I not really sure why but Fe is not binding to the resin because Fe titration before and after resin binding in batch purification (not column) is giving the same Fe concentration.
After this results I turned to the following Biorad Manual for Ion contaminant removal http://www.bio-rad.com/LifeScience/pdf/ ... n_1825.pdf
and it suggests the AGW 50 resin for heavy metal removal. However, the caracteristicis of the resin as to particle size and functional groups are almost the same.
May you help me with this? Why won´t I be able to use the Macro Prep Resin? Any recommended protocol?
Thank a lots,
Thank a lots,
