UV spectrum in report (Empower 3)
Posted: Wed Nov 12, 2014 8:19 am
by artsjeroen
Is it possible to get a report of PDA-data, where only the UV-spectrum at a specified retention time is shown?
I've been struggling with Report Publisher for some time now.
I've tried extracted spectral plots, and in the properties I select the tab Spectra and enter the desired Retention time. But every time I try that, Report Publisher crashes.
Re: UV spectrum in report (Empower 3)
Posted: Wed Nov 12, 2014 4:30 pm
by Hollow
What release of empower 3 do you have? FR2 SR1?
There is a bug in it when you'd specified some peak "selection" (e.g. only # peaks per page) and then try to generate a report of a chromatogram without any integrated peaks in it (e.g. blank). It will crash.
Try if it still crashes when you select a result with at least one peak (if it's baseline, just manually integrate some noise).
PS: if this is your failure too, please report this to Waters too. My request is still pending in Milford.
