Perkin Elmer Flexar Autosampler
Posted: Mon Nov 10, 2014 11:58 pm
Has anyone changed the flush valve on a Perkin Elmer Flexar 200? Also, the software to manually direct control the autoinjector and valve will not communicate with the autosampler. I need this control to position the valve for removal.
During a recent run, my peaks disappeared mid run. I tracked the problem to the Perkin Elmer Flexar 200 autosampler. Between injections, there are bubbles in the rinse line that just go back and forth between the syringe and the solvent rinse container. I attached pictures below from a video of the flush cycle. The video is on http://youtu.be/Qr1wfjp34zc
Any advice will be greatly appreciated.
