Rinsing out the metals
Posted: Thu Nov 06, 2014 9:21 am
I have to analyze a base with an impurity which is a base also.
Sometimes, the base is tailing very intensive and I can use the column only for about 50 injections and then the SST fails.
On the same instrument as I perform this analysis, also the parabens of a zinc containing cream are determined.
Thus, I thought that eventually zinc ions might be left back in the system and I intend to try a rinsing with a chelating agent.
I am not sure whether there are better possibilities than EDTA. Could you recommend one? And which concentration should I use?
Thank you very much.
Florian
Florian
