GCMS troubleshooting - episode 2
Posted: Fri Oct 24, 2014 4:41 pm
Good morning,
Still fighting with this 5973......
This one has a diffusion pump, but cannot get it to turn on. I'm getting error #4; "Difficulty with Mass filter electronics".
Looked up the error, found that the following could be wrong:
1. vacuum manifold pressure too high
2. RFPA not correctly adjusted
3. mass filter contacts shorted or otherwise not working
4. mass filter not working correctly
5. MSD electronics not working correctly
What I've done;
1. checking the pressure through the software: in Diagnostics/edit ms params, forline pump is at ~14(mTorr?).
2. also in Diagnostics/set RFPA - attempted adjustment failed; clicking on set RFPA causes software to do I/O test. I dont know why. (I/O test passes)
3.-5. Only thing I can think of here, is to re place the entire quad assembly (the door)
Called Agilent, waiting for a callback.
If anyone has insight into this, I would be happy to hear any suggestions.
What I've done;
