System Suitability tests for chromatography data freeware
Posted: Fri Oct 24, 2014 12:42 pm
by cterrien
Hi everyone!. I need to make System Suitability tests (number of theoretical plates, assymetry, k´, ...) on my chromatography data and I´m looking for a software <free or trial version>. Does anyone knows where could I find it?
Thanks!!!!
Re: System Suitability tests for chromatography data freewar
Posted: Mon Oct 27, 2014 9:11 am
by CE Instruments
Most data systems include this facility as standard. What is your data and which package was it acquired on ?
Posted: Mon Oct 27, 2014 3:37 pm
by cterrien
I have Empower 3 but without the SST extension included. That´s the reason for what I´m looking for some free or trial software!!
Posted: Mon Oct 27, 2014 7:48 pm
by Hollow
Some peak parameters are available even without the sst option, I guess symmetry factor, width at baseline should be.
with an export method you could export these values as an ASCII file, which can be imported in excel.
There you should be able to do the calculations as needed
