Proteins @ QqQ
Posted: Fri Oct 24, 2014 11:27 am
Greetings!
Recently, I've been playing a bit with proteins analysis by LC-MS-MS (mostly for teaching, not for serious research). While Mw determination from charge series worked as charm, I have not managed to get any fragmentation at lower collision energies (< 50 V), and at higher (80 V and above) the molecules disintegrated to amino acids. Does anyone know why I was unable to obtain y- and b-ions?
I have used Agilent Technologies 6410A triple-quad with ESI. Samples (e.g. lysozyme) were injected via HPLC autosampler, directly connected to MS, using 0.1 % HCOOH/MeOH (1:1) as mobile phase, at flow of 0.5 mL/min.
ESI parameters were: nebulizer gas (N2) pressure 50 psi, drying gas (N2) temperature 350 °C and flow 10 L/min, capillary voltage 4000 V, fragmentor voltage 300 V (optimized for highest intensity of [M+H]+), positive ionization.
QqQ parameters were: Product Ion Scan mode, collision energies 10-140 V (in 20-30 V increments). Collision gas was N2.
